A note about A.I. Generated Suggestions
The Zorin Forum Guidelines include fair use; that members that copy and paste citations of other sources include the credit or attribution for the work.
This applies to the use of A.I. generated suggestions in troubleshooting.
Please remember that if you are providing a suggestion to assist troubleshooting and post an excerpt or content provided by A.I. generation to attribute the source and nature of the response.
For example, if you used Gemini, you could post.
Here is what Gemini A.I. suggests might work
followed by the copy and pasted excerpt.
Not only is this aligned with the forum guidelines, it assists member decision making as to how to vet and research a suggestion before applying terminal commands or installing packages.
Sensible. If I use mojeek and it does not get what I am looking for, I click on the Brave button it supplies. This gives all responses from the Brave search engine. If A.I. used by Brave brings back a gathered response it appears at the top. It does not always happen though, but I usually provide links when there is one. I am more than happy to state what a Brave A.I. has come back with but can't go to the trouble of copying all the links it has used to put the answer together, or is this also required?
I might compare this to a person stating that they got information from Wikipedia.
Most Wiki's have a long list of links included, but you do not need to give all of those links - referencing the primary source is more than enough for any user to follow the chain.
I would say, no. Just annotating when a response is A.I. generated as opposed to self-written is sufficient.
This is also similar to how I would link to another site where I got the reply that I'm providing. For example, I did that here to provide the answer and also where I got it from:
