Few weeks back i faced issues with flatpak version of edge and also vscode has issues with it. Discord also has issues on sharing screen.
So we made a package manager in bash script.
it's in beta and we are not well versed in bash ( it's confusing ).
It looks like this downloads the package from the official project website and installs it, the same way you could manually do as well. It's really nice that this tool checks for latest versions available and update it for you, and the fact that it only supports very few packages probably means a lot of care goes into making sure nothing breaks between updates.
But I wouldn't say this fixes Flatpak issues, that title is a bit misleading.
For example, if you already have Discord installed from Flathub, and then use this tool to "fix" it you will end up with two versions of Discord installed in your system.
This is more a utility tool to work around the limitation of some of these popular packages that may not be available as .deb files on the official repositories. But it's pretty cool to have nonetheless.
Yeah , we just install the .tar.gz package, if not available then we can only support whatever that application supports.
Doing it manually is an option but this just makes it easier.
I was thinking the same today , will ask user if he has installed ( something like this ).
