A Problem in TPM2
I'm trying to set up LUKS automatic unlocking via TPM2 on Zorin OS 18.1 Pro (Dual-boot with Windows 11), but I've hit a wall with hardware communication.
The Problem:
  1. Zorin OS:'tpm2_pcrread' and other 'tpm2-tools' fail with TCTI errors: 'Could not load tcti, got: "device:/dev/tpm0"'. However, I can manually read PCRs via 'cat /sys/class/tpm/tpm0/pcr-sha256/0'.
  2. Windows 11: 'Get-Tpm' previously reported 'RestartPending: True'. After some BIOS tweaks (removing Admin password), it currently intermittently reports 'TpmPresent: False'.
  3. Hardware Context: This is an ASUS TUF Gaming F16 (2024). The motherboard was recently replaced by official support.
Troubleshooting Done:
Confirmed Intel PTT/Security Device Support is Enabled in BIOS.
Disabled VMD Controller to ensure NVMe/TPM visibility.
Attempted 'Clear-Tpm' in Windows, but no PPI (Physical Presence Interface) confirmation prompt (F12) appears on reboot.
Attempted a "Cold Boot" (60s power button press) to reset the EC, with inconsistent results.
My Goal: I need to resolve the RestartPending state or the "missing" hardware node so I can enroll my LUKS keys. It seems the BIOS is failing to trigger the PPI prompt required to clear the TPM.
These are my system specs:
Model: ASUS TUF Gaming F16 FX607JV
CPU: Intel i7-13650HX
GPU: Nvidia GeForce RTX 4060 Laptop
Zorin OS: Zorin OS 18.1 Pro
TPM: Intel PTT (Firmware TPM 2.0)
Forgive my using AI for I am a Taiwanese with poor English skill.
Is Your BIOS up to date? Maybe it would be easier to disable TPM and type in a Password for encrypting?
Yeah my BIOS is the latest and it does not provide an option to switch the TPM status.
Besides, in order to enhance the security, my LUKS password was set to be long —— it is 48-digit. I do not really want to type it every time.
Quite Strange.
