Frog
December 25, 2021, 11:23pm
1
I installed VLC a few days ago as recommended by a bunch of board members and have a problem with the program .... I installed it to run video objects only not my photos .... I like my gThumb for pictures ....
Whenever I open my Pictures Folder VLC loads and shows the photo for about 20 sec closes and displays the VLC splash screen ....
I need to find a way for to only open pictures in my gThumb app .... any suggestions will be appreciated .... see photos below .....
carmar
December 25, 2021, 11:38pm
2
For any file: Right click -> properties-> open with -> choose default application to open that type of file.
Frog
December 26, 2021, 12:01am
3
I tried that and it worked with the first photo .... but then reverted right back to VLC on the next one ....
Frog
December 26, 2021, 12:49am
4
I think I found the solution .... VLC was trying to open all png files as movies so I did this ....
VLC/ Tools/ Preferances/ Video/ Format/ ..... change png to jpg
Frog
December 26, 2021, 2:03am
5
Nope that didn't work either .... batting 0% today ....
@Frog How did you install VLC? Not a Snap or Flatpak by chance?
Bourne
December 26, 2021, 2:44pm
8
Tried xnview or irfanview.
Frog
December 26, 2021, 11:02pm
9
I don't think so ..... how do I find out what is installed using Snap or Flatpak .... I normally use the terminal or Synaptic ....
carmar
December 27, 2021, 1:51am
10
If it’s not on Synaptic it’s likely a Snap. Confirm with snap list and flatpak list
Frog
December 27, 2021, 2:13am
11
Interesting ... doesn't look like it was installed by them either .....
mike@mike-ROG-Strix-G731GT-G731GT:~$ snap list
No snaps are installed yet. Try 'snap install hello-world'.
mike@mike-ROG-Strix-G731GT-G731GT:~$ flatpak list
Na… Application … Version Branch Origin Installation
OB… …oject.Studio 27.1.3 stable flathub system
Bl… …ojai.Blanket 0.5.0 stable flathub system
Ha… …andbrake.ghb 1.4.2 stable flathub system
Fr… …app.FreeTube 0.15.1 Beta stable flathub system
Ko… …seadve.Kooha 1.2.1 stable flathub system
Co… …skes.gcolor3 2.4.0 stable flathub system
TA… ….Plugins.TAP 1.0.1 20.08 flathub system
TA… ….Plugins.TAP 1.0.1 21.08 flathub system
SWH ….Plugins.swh 0.4.17 20.08 flathub system
SWH ….Plugins.swh 0.4.17 21.08 flathub system
Fr… …top.Platform 20.08.16 20.08 flathub system
Fr… …top.Platform 21.08.7 21.08 flathub system
de… …m.GL.default 19.08 flathub system
Me… …m.GL.default 21.1.8 20.08 flathub system
Me… …m.GL.default 21.3.1 21.08 flathub system
In… ….VAAPI.Intel 19.08 flathub system
In… ….VAAPI.Intel 20.08 flathub system
In… ….VAAPI.Intel 21.08 flathub system
ff… ….ffmpeg-full 20.08 flathub system
ff… ….ffmpeg-full 21.08 flathub system
op… …orm.openh264 2.1.0 2.0 flathub system
GN… …workDisplays 0.90.4 stable flathub system
Pa… …PasswordSafe 5.1 stable flathub system
GN… …ome.Platform 3.38 flathub system
GN… …ome.Platform 40 flathub system
GN… …ome.Platform 41 flathub system
Br… …theme.Breeze 3.22 flathub system
Zo… …rinBlue-Dark 3.22 zorinos system
Zo… …inBlue-Light 3.22 zorinos system
Zo… …inGreen-Dark 3.22 zorinos system
Zo… …nGreen-Light 3.22 zorinos system
Zo… …rinGrey-Dark 3.22 zorinos system
Zo… …inGrey-Light 3.22 zorinos system
Zo… …nOrange-Dark 3.22 zorinos system
Zo… …Orange-Light 3.22 zorinos system
Zo… …nPurple-Dark 3.22 zorinos system
Zo… …Purple-Light 3.22 zorinos system
Zo… …orinRed-Dark 3.22 zorinos system
Zo… …rinRed-Light 3.22 zorinos system
In… …ape.Inkscape 1.1.1 stable flathub system
Ad… …tyle.Adwaita 5.15 flathub system
KD… …kde.Platform 5.14 flathub system
KD… …kde.Platform 5.15 flathub system
KD… …kde.Platform 5.15-21.08 flathub system
QG… …nomePlatform 5.14 flathub system
QG… …nomePlatform 5.15 flathub system
QG… …nomePlatform 5.15-21.08 flathub system
Qt… …mTheme.QtSNI 5.14 flathub system
Qt… …mTheme.QtSNI 5.15 flathub system
Qt… …mTheme.QtSNI 5.15-21.08 flathub system
QG… …m-decoration 5.14 flathub system
QG… …m-decoration 5.15 flathub system
QG… …m-decoration 5.15-21.08 flathub system
Ha… …g.kde.haruna 0.7.3 stable flathub system
Kd… …kde.kdenlive 21.08.3 stable flathub system
no… ….ImageLounge 3.16 stable flathub system
carmar
December 27, 2021, 4:32am
12
Windows version through Wine (Windows app support)?
To check, open your home folder and of hidden files are not visible then press ctrl+h to show them. There would be a folder .wine - if no folder then you didn’t use wine.
Frog
December 27, 2021, 4:38am
13
Nope .... not there either ....
Frog
December 27, 2021, 4:49am
15
Yup ..... I'm beginning to think the martians sent it to me .... LOL .... just like this jittery screen I get when I'm in the forum .... when I am typing the last item posted that is visible in the top half of the screen has the jitters .... LOL .... if I go to 1/2 size screen it quits .... figure that one out .... no way to take a screenshot cause I tried .... LOL
If you open Zorin Software Store and Installed Tab. Do you see VLC as installed app there?
If you do, scroll down and you will see the source.
Maybe through apt?
Check using:
apt list --installed
Frog
December 27, 2021, 11:05pm
18
I'm beginning to think maybe I deleted the program as I can't seem to find it anywhere and it isn't listed in my All Applications or Installed in the App Store ....
I've done so many installs and uninstalls the past few days I'm not sure what I did ....
virtualbox-dkms/focal-updates,now 6.1.26-dfsg-3~ubuntu1.20.04.2 amd64 [installed,automatic]
virtualbox-qt/focal-updates,now 6.1.26-dfsg-3~ubuntu1.20.04.2 amd64 [installed,automatic]
virtualbox/focal-updates,now 6.1.26-dfsg-3~ubuntu1.20.04.2 amd64 [installed,automatic]
vivaldi-stable/now 5.0.2497.28-1 amd64 [installed,upgradable to: 5.0.2497.32-1]
vlc-bin/focal,now 3.0.9.2-1 amd64 [installed,auto-removable]
vlc-data/focal,focal,now 3.0.9.2-1 all [installed,automatic]
vlc-l10n/focal,focal,now 3.0.9.2-1 all [installed,auto-removable]
vlc-plugin-base/focal,now 3.0.9.2-1 amd64 [installed,automatic]
vlc-plugin-notify/focal,now 3.0.9.2-1 amd64 [installed,auto-removable]
vlc-plugin-qt/focal,now 3.0.9.2-1 amd64 [installed,auto-removable]
vlc-plugin-samba/focal,now 3.0.9.2-1 amd64 [installed,auto-removable]
vlc-plugin-skins2/focal,now 3.0.9.2-1 amd64 [installed,auto-removable]
vlc-plugin-video-output/focal,now 3.0.9.2-1 amd64 [installed,automatic]
vlc-plugin-video-splitter/focal,now 3.0.9.2-1 amd64 [installed,auto-removable]
vlc-plugin-visualization/focal,now 3.0.9.2-1 amd64 [installed,auto-removable]
wamerican/focal,focal,now 2018.04.16-1 all [installed]
wbritish/focal,focal,now 2018.04.16-1 all [installed]
wget/focal-updates,now 1.20.3-1ubuntu2 amd64 [installed,automatic]
Bourne
December 28, 2021, 11:33pm
19
Maybe reinstall help. I installed from webbrowser vlc website.
system
Closed
March 28, 2022, 11:34pm
20
