Hey my ACI8800 wifi adapter is not working properly and also my another wifi adapter Realtek Semiconductor Corp. RTL8188FTV is also not working
.Pls help
I found something to:
It might be a bit ... complex:
There exists a Github Site for installing a Driver for this:
You can install it from there or You add a Repo to install the Driver:
But You should take a Look at the additional Steps on the Github Page if only installing the Driver doesn't help.
On github there are also some drivers for ACI8800 from different persons, but most of them you need to compile and I'm not sure if they will work on the 6.17 kernel Zorin uses or if it is better to try with an older kernel.
My man what I will say now it works like for 1 month and then again when i did update of zorin os it breaks the driver also. By the way i am newbie to linux. I use linux mint for 2 months but i was dissatisfied with it so i tried zorin os.I will say its good except the wifi drivers.I am 18 years of old by the way. I am from India
When the wlan problem was caused by a kernel update it can help to boot with an older kernel.
At boot select in grub menu "Advanced options for Zorin" and then select an older kernel to boot from.
If it helps you can set this kernel as default to boot for a while until the next updates will solve the problem.
