Activate Zorin OS pro
Hi guys,
I recently purchased the Zorin OS 16 pro version but in the installation process it never asked me for the key and now it's showing I have basic Zorin OS 16 installed.
Can someone please help me with letting me know how to activate my copy of OS?
There are no DRM and or activation processes on Zorin 16 Pro. There are no issues here :slight_smile:
Zorin 16 Pro is a way to support the developers and the Zorin team did not include any DRM measures in their product.
In order to install Zorin 16 Pro, download the .ISO file that has been emailed to you and use that to install Z16 Pro.
Hey @anon37206250,
Thanks for quick responses.
If that is the case I can't find all the themes that pro has in my installation.
Is there a way to check if my installation is pro or not, like from any command or menu?
I checked about but there I see only Zorin OS 16.
Did you download the .iso from a link that was sent in an email to you by the ZorinGroup - or did you download from the Zorin OS website?
I did a quick check in the settings menu and there does not seem to be an option that reflects this.
A dirty way to do it would be to see if the Wallpapers/Apps seen on the Z16 Pro page are available on your device.
Also Z16 Core takes roughly 9.5GB of space while Z16 Pro takes about 25 GB.
Or use Neofetch.
Yes I downloaded from link only.
NO,No,NO
No No No GIF
