Activating accessibility > zoom > color effects > low brightness, does it increase battery consumption?
I'm not sure if it would cause that much of an increase in battery drain? Although I'm not sure if anyone has actually put any testing into that really. Regardless, I have a feeling that if it went one way or the other on battery drain, it's probably minimal to the point of something not to worry about.
At least, that's what I would presume. Maybe I'm way off base here.
I think that only brightness would do, but if you're uncertain you can see if running a session with your default settings and another with these settings there's a relevant difference, just see how much the battery consumed in a certain time. Remember to not do anything different in one of the sessions (like opening a game or the browser) otherwise you'll have untrustful info, test the same exact conditions for both sessions.
