Booting worked or the Wifi worked on the 5.15.0-71 kernel?
Booting unfortunately
Ok... here is where we stand currently:
We have probed the module and that did not work.
We have tried it on a known working kernel that worked prior to it ceasing to work - but that did not work.
We have set the appropriate options and that did not work...
And we have ensured a working supported driver.
At this point, I can only suspect that the Wifi Card itself is experiencing failure - resulting in the internet suddenly ceasing to work.
You may need to use a Wifi Dongle - or replace the card.
I see so at where we stand , i can either check it's hardware or use wifi dongle well anyways thanks alot for your help . I hope you have a good day
