Hello there,
Some of Gnome based distro are support that we push the "speaker" icon on volume settings, it mute it. It possible to add this feature to Zorin?
Hello there,
Those distributions are probably using a higher version of Gnome. ZorinOS 17 uses Gnome 43, but for example Fedora uses Gnome 45 which does have the ability to mute sound using this icon as a toggle button.
It'd be nice to have this added at a later point release, though.
Yes, now i found it that this feature will come with Gnome 44. But, this extension are add this to 43. now i installed it, but it would be good to integrate it to Zorin
