After fresh installation i have problems with apperance.
In command terminal i have this
Failed to load module "appmenu-gtk-module"
[GFX1-]: glxtest: VA-API test failed: failed to initialise VAAPI connection.
I seeing only desktop with icons.
I cannot go to menu and taskbar is missing.
I get some errors and some webside freedesktop.org
How it is possibe after fresh installation when i installed only steam and discord the Zorin start crashing?> this is little annoying.
The pc hardware parts isn't old.
urm
Can a Zorin OS Pro user please confirm the apt command to install --reinstall the zorin-os-desktop-premium?
I reboot and taskbar and desktop back on place.
In other words "Have you tried turning it off and on again?"
I saw that episode movies. Yes restart help you but shutdown not exactly because a ram cache will not a erase or clean.
I've got an old Asus Motherboard that scrubbed RAM on shut-down!
The drivers was updated automatically, no needed searching.
i gived a command sudo apt --reinstall zorin-os-desktop with premium not working.
I have installed Zorin and sometimes i need use in terminal command pulseaudio -k to repair my audio in youtube channel. I am using sound blaster audio card. One what i can do with this data for testing things but not for daily driver. Propably that is issue with hardware what i have. Once what i can learning never buying cheap motherboard or processor without integrated gpu. Case,ram and power supply and gpu always you can move to new future machine if socket and ram is compatibility.
lspci
00:00.0 Host bridge: Intel Corporation Device 9b53 (rev 03)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 03)
00:14.0 USB controller: Intel Corporation Device 43ed (rev 11)
00:14.2 RAM memory: Intel Corporation Device 43ef (rev 11)
00:16.0 Communication controller: Intel Corporation Device 43e0 (rev 11)
00:17.0 SATA controller: Intel Corporation Device 43d2 (rev 11)
00:1c.0 PCI bridge: Intel Corporation Device 43bf (rev 11)
00:1d.0 PCI bridge: Intel Corporation Device 43b2 (rev 11)
00:1d.3 PCI bridge: Intel Corporation Device 43b3 (rev 11)
00:1f.0 ISA bridge: Intel Corporation Device 4388 (rev 11)
00:1f.4 SMBus: Intel Corporation Device 43a3 (rev 11)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Device 43a4 (rev 11)
01:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P400] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 PCI bridge: PLX Technology, Inc. PEX8112 x1 Lane PCI Express-to-PCI Bridge (rev aa)
04:00.0 Multimedia audio controller: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
I cannot believe the Devuan installation on virtual box taken me all day.
