I wanna just try Wayland but after logging on, the desktop on my "main" monitor is larger and there is a new ghost display on 2560x1080 60hz. The only 2560x1080 monitor that is in my room right now is my broken one. When in the settings, this third ghost monitor is a Unknown 29".
Quick answer: (all I have time for ATM)
Return back to X11/Xorg after a computer restart, at login screen. Wayland is buggy on Linux, and is not ready for Prime time.
Okay okay. I will do. I was told to try Wayland because of the way my games were choppy after one of my monitors breaking.
When You would be on a more upto-date Desktop Version, trying it wouldn't be a bad Idea. But here on Zorin Dnome 43 is used as the Base for the Zorin Desktop on Core. And the Wayland implementation isn't there so far that it is really good for using with Nvidia Cards. When Zorin 18 with a newer gnome Version as Base will come, You can try it again. For now, You should stay on Xorg.
