I'm using Zorin OS 16 Pro. Do I need akonadi mail reader ? If not how do I remove it? I'm using Evolution as my mail client.
Probably best to check using Synaptic.
Mark Akonadi for removal, click Apply once. In the new pop-up, the expandable list will tell you if Evolution is impacted. You can then decide if you wish to proceed.
Thank you.
Marked solution. 248
