I get the following output:
toedliches_auge@ToedlicherPC-linux-zorin:~$ chmod 644 /usr/lib/sudo/sudoers.so
chmod: Zugriff auf '/usr/lib/sudo/sudoers.so' nicht möglich: Datei oder Verzeichnis nicht gefunden
toedliches_auge@ToedlicherPC-linux-zorin:~$ chown -R root /usr/lib/sud
chown: Zugriff auf '/usr/lib/sud' nicht möglich: Datei oder Verzeichnis nicht gefunden
chmod: Unable to access '/usr/lib/sudo/sudoers.so': File or directory not found
chown: Unable to access '/usr/lib/sud': file or directory not found
It was a shot. It is not finding due to those directories not being in Home Directory.
This is a catch-22... you need to elevate to sudo in order to adjust sudo file...
If you launch File Manager and navigate to /usr/lib/sudo/sudoers.so and right click sudoers.so, move to permissions, what does the Popover show?
Same for '/usr/lib/sud'
this is what I get from the console:
toedliches_auge@ToedlicherPC-linux-zorin:~$ chmod 644 /usr/libexec/sudo/sudoers.so
chmod: Beim Setzen der Zugriffsrechte für '/usr/libexec/sudo/sudoers.so': Vorgang nicht zulässig
chmod: When setting access rights for '/usr/libexec/sudo/sudoers.so': operation not permitted
I keep needing to attend other details and be away from the computer, so I am operating while distracted. Let me either return to this in a bit - or another use may offer help soon.
I just noticed something else. For some reason my hard drive just fills up. There were still 200 GB free and now they are full. I then uninstalled a game and the free space gradually filled up. I don't know if this information helps in any way.
I don't know, but somehow I think a fresh install might be best, but I would prefer not to reinstall. What do you think? If so, is there a way to reinstall Zorin so, that my files, data, installed programs, etc. still remain there and only Zorin itself is reinstalled?
This sounds like /var/log may be filling.
You might check jounralctl or clean out logs with
sudo journalctl --vacuum-time=1s
and see if that space used is reduced.
I pretty much always think a fresh install is best.
I, too, suffer from wanting to avoid it. But the reality is, it is never as bad as I fear and it reduces clutter, clears out junk I have forgotten about and gives a nice fresh clean start. This reduces conflicts that build up, as well.
I do back up personal files, docs, music, etc on an external drive.
For reinstalling software, I use this method:
Sorry for the delays and short messages: It is hectic here...
