Hi, i just made a fresh install of ZorinOS 17 Core on my PC.
I also added a dedicated GPU (Sapphiere Radeon RX 7600).
Now i have the following behaviour which i'm unsure about if it's correct: Without the Radeon-GPU added the GNOME>Settings>Info shows "Integrated Graphics" or similar, so everything seems fine.
But with Radeon-GPU installed i get from GNOME>Settings>Info: GFX1102 (gfx1102, LLVM 15.0.7, DRM 3.54, 6.5.0-14-generic).
So what does this mean? I Expected to find the product-name of my GPU. Is my dGPU now recognized and used by ZorinOS?
Also i'm missing the option "launch with dedicated GPU" by right-clicking an App? (i now it from my notebook)
No, i think it is not listed there. From what i found in the internet the manufacturere (german: Hersteller) should be sapphiere and the product (german: Produkt) should be Radeon RX 7600 or similar?
~$ lshw -C video
WARNUNG: Sie sollten dieses Programm mit Systemverwalterrechten (root) ausführen.
*-display
Beschreibung: VGA compatible controller
Produkt: Advanced Micro Devices, Inc. [AMD/ATI]
Hersteller: Advanced Micro Devices, Inc. [AMD/ATI]
Physische ID: 0
Bus-Informationen: pci@0000:03:00.0
Logischer Name: /dev/fb0
Version: cf
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: vga_controller bus_master cap_list rom fb
Konfiguration: depth=32 driver=amdgpu latency=0 resolution=3840,2160
Ressourcen: irq:77 memory:d0000000-dfffffff memory:e0000000-e01fffff ioport:f000(Größe=256) memory:fcc00000-fccfffff memory:c0000-dffff
(With sudo the output is the same.)
But my two monitors, connected to the Radeon-GPU, are working. So the DisplayPort Outputs are "recognized/used" by the mainboard.
