From this link what i send they tested. One what I reading on websides your laptop working only with some kernel and some version distribution.
That mean if you doing some instructions the distribution and kernel must be compatibility to your hardware device accelerator graphic card and processor.
Yes it is but the problem what is it when he tried updated with Tahiti he missing some files firmware.
He must focus on both things because a accelerator graphic must be compatibility with motherboard what he have on laptop.
It could be propably what I saw Tahiti when he installed mostly drivers was installed properly. It could be missing files from a side on motherboard what blocking signal to vga port. Here is interesting connected with 3 monitors and working. [SOLVED] R9 280X - neither amdgpu or radeon enabled - MX Linux Forum
I wish help fix that problem with this graphic card but I have some motor in my Country. I know if you changed a country in google motor then you get another searching motor and answear. Some countries have a filter do not show some information.
Hi gents, made some progress bought a second hand gpu for testing and reinstalled zorin os from scratch and well its automatically detecting the radeon driver and all monitors (its an hd7950 also).... ive got both currently plugged in. I guess the old gpu has a kind of failure or simply isnt being detected correctly...
Only the opencl 1.2 is missing its seems now since im using the open source driver.
Do you know if the ppa oibaf would solve this? Gaming ect would work then also..
I used from here a topic for gaming pro. It helps much to working properly.
So in your old laptop gpu was died what i reading from some websides your problems could be a died gpu?
Hi Bourne, my pc is a desktop (not a laptop). I didn't identify it as a failure just trying to find a solution by all means to have a workable pc... Maybe it isnt dead at all just not recognized by MB..
Hello @GaiusMarius and it is good everything working.
I wondering what big all monopoly corporation have idea? All graphic cards price are go to sky. I saw many people buying also threadripper 1920x.
So i understand all people buying everything what exist to buying simple PC.
I don't know but I am scarred this expensive graphic cards?
The once what I heard the new computers will be more office because graphic cards are expensive. Maybe they want people buying xbox or playstation?
I heard on linux you can playing with emulator some games from PS4.
If they have idea selling a pc laptops with arm mobile processors then this laptops not will be a gaming.
Hi,, thank you for the command just ran it and updates were triggered and seems some progress :)))
When i run clinfo
the output:
Number of platforms 1
Platform Name Clover
Platform Vendor Mesa
Platform Version OpenCL 1.1 Mesa 21.3.0-devel (git-6f9f350 2021-09-19 focal-oibaf-ppa)
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd
Platform Extensions function suffix MESA
Number of devices 2
Device Name AMD TAHITI (DRM 2.50.0, 5.11.0-34-generic, LLVM 12.0.1)
Device Vendor AMD
Device Vendor ID 0x1002
Device Version OpenCL 1.1 Mesa 21.3.0-devel (git-6f9f350 2021-09-19 focal-oibaf-ppa)
Driver Version 21.3.0-devel
Device OpenCL C Version OpenCL C 1.1
Device Type GPU
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Max compute units 28
Max clock frequency 900MHz
Max work item dimensions 3
Max work item sizes 256x256x256
Max work group size 256
=== CL_PROGRAM_BUILD_LOG ===
fatal error: cannot open file '/usr/local//usr/lib/clc/tahiti-amdgcn-mesa-mesa3d.bc': No such file or directory
Preferred work group size multiple <getWGsizes:1200: create kernel : error -46>
Preferred / native vector sizes
char 16 / 16
short 8 / 8
int 4 / 4
long 2 / 2
half 0 / 0 (n/a)
float 4 / 4
double 2 / 2 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals No
Infinity and NANs Yes
Round to nearest Yes
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Correctly-rounded divide and sqrt operations No
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Address bits 64, Little-Endian
Global memory size 3221225472 (3GiB)
Error Correction support No
Max memory allocation 2254857830 (2.1GiB)
Unified memory for Host and Device No
Minimum alignment for any data type 128 bytes
Alignment of base address 32768 bits (4096 bytes)
Global Memory cache type None
Image support No
Local memory type Local
Local memory size 32768 (32KiB)
Max number of constant args 16
Max constant buffer size 67108864 (64MiB)
Max size of kernel argument 1024
Queue properties
Out-of-order execution No
Profiling Yes
Profiling timer resolution 0ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Device Extensions cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp64 cl_khr_extended_versioning
Device Vendor AMD
Device Type GPU
char 16 / 16
short 8 / 8
int 4 / 4
long 2 / 2
half 0 / 0 (n/a)
float 4 / 4
Denormals No
Round to zero No
Denormals Yes
Round to zero Yes
Image support No
Queue properties
Profiling Yes
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) Clover
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [MESA]
clCreateContext(NULL, ...) [default] Success [MESA]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (2)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (2)
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.11
ICD loader Profile OpenCL 2.1
Only noticed 1 fatal error message in the output: fatal error: cannot open file '/usr/local//usr/lib/clc/tahiti-amdgcn-mesa-mesa3d.bc': No such file or directory
Does this mean the openCl version installed on each is 2.1 :)? Should i try and solve the fatal error also?
