Do you know how to activate/install the OpenCL 1.2 for the AMD Tahiti PRO [Radeon HD 7950/8950 OEM / R9 280]?
I've spent a lot of time going through the forums without finding a solution besides downgrading to ubuntu 14.04 or 12.02 where i could install the proprietary driver 15.9.
When you have performed your searches for you isolate them to zorin 16? I ask because zorin 16 is based on Ubuntu 20.04, but with the kernel updates, some of the Ubuntu 21.04 solutions work as well. You may want to attempt those searches again with the Ubuntu versions.
I know my card supports OpenCL 1.2 however when i run clinfo it states that the device is running OpenCL 1.1
Output:
Number of platforms 1
Platform Name Clover
Platform Vendor Mesa
Platform Version OpenCL 1.1 Mesa 21.3.0-devel (git-039ed2d 2021-09-22 focal-oibaf-ppa)
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd
Platform Extensions function suffix MESA
Number of devices 1
Device Name AMD TAHITI (DRM 2.50.0, 5.11.0-36-generic, LLVM 12.0.1)
Device Vendor AMD
Device Vendor ID 0x1002
Device Version OpenCL 1.1 Mesa 21.3.0-devel (git-039ed2d 2021-09-22 focal-oibaf-ppa)
Driver Version 21.3.0-devel
Device OpenCL C Version OpenCL C 1.1
Device Type GPU
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Max compute units 28
Max clock frequency 900MHz
Max work item dimensions 3
Max work item sizes 256x256x256
Max work group size 256
=== CL_PROGRAM_BUILD_LOG ===
fatal error: cannot open file '/usr/local//usr/lib/clc/tahiti-amdgcn-mesa-mesa3d.bc': No such file or directory
Preferred work group size multiple <getWGsizes:1200: create kernel : error -46>
Preferred / native vector sizes
char 16 / 16
short 8 / 8
int 4 / 4
long 2 / 2
half 0 / 0 (n/a)
float 4 / 4
double 2 / 2 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals No
Infinity and NANs Yes
Round to nearest Yes
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Correctly-rounded divide and sqrt operations No
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Address bits 64, Little-Endian
Global memory size 3221225472 (3GiB)
Error Correction support No
Max memory allocation 2254857830 (2.1GiB)
Unified memory for Host and Device No
Minimum alignment for any data type 128 bytes
Alignment of base address 32768 bits (4096 bytes)
Global Memory cache type None
Image support No
Local memory type Local
Local memory size 32768 (32KiB)
Max number of constant args 16
Max constant buffer size 67108864 (64MiB)
Max size of kernel argument 1024
Queue properties
Out-of-order execution No
Profiling Yes
Profiling timer resolution 0ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Device Extensions cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp64 cl_khr_extended_versioning
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) Clover
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [MESA]
clCreateContext(NULL, ...) [default] Success [MESA]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.11
ICD loader Profile OpenCL 2.1
Not sure what to do to install openCL 1.2. I read that via an SDK it is possble but was unable to find a solution.. The output is after i ran your command.
Yes i tried the commanded you provided above and then i shared the output. As it states it seems version OpenCl1.1 is being used though 2.2 is installed. I know my gpu can handle up to OpenCL1.2 (not possible to use >=2.0) thus my question : how can i install OpenCL1.2?
When i tried installing the deb it mentions that it is already installed:
The .deb package I linked above contains it. If you need, you can double check this.
Save and extract the file. Then extract Control.
Open the Control file - Look to the Provides line:
Package: ocl-icd-libopencl1
Source: ocl-icd
Version: 2.2.11-1ubuntu1
Architecture: amd64
Maintainer: Ubuntu Developers ubuntu-devel-discuss@lists.ubuntu.com
Original-Maintainer: Vincent Danjean vdanjean@debian.org
Installed-Size: 114
Depends: libc6 (>= 2.4)
Suggests: opencl-icd
Conflicts: amd-app, libopencl1, nvidia-libopencl1-dev
Replaces: amd-app, libopencl1, nvidia-libopencl1-dev
Provides: libopencl-1.1-1, libopencl-1.2-1, libopencl-2.0-1, libopencl-2.1-1, libopencl1
Section: libs
Priority: extra
Multi-Arch: same
Homepage: https://forge.imag.fr/projects/ocl-icd/
Description: Generic OpenCL ICD Loader
OpenCL (Open Computing Language) is a multivendor open standard for
general-purpose parallel programming of heterogeneous systems that include
CPUs, GPUs and other processors.
This package contains an installable client driver loader (ICD Loader)
library that can be used to load any (free or non-free) installable client
driver (ICD) for OpenCL. It acts as a demultiplexer so several ICD can
be installed and used together.
As to why your hardware is not using it... I do not know.
But I am looking for information...
I am not sure. I had seen that one and a few others that also mentioned AMD dropping support as well. But I had not really read too deeply since you are, at least, using 1.1
