An Installation Error
Yes i have restarted and here is info @AZorin
rainbow@rainbow-ASUS-BR1102FGA-BR1102FGA-BR1102FGA:~$ sudo fwupdmgr refresh
[sudo] password for rainbow:
Firmware metadata last refresh: 14 hours ago. Use --force to refresh again.
rainbow@rainbow-ASUS-BR1102FGA-BR1102FGA-BR1102FGA:~$ sudo fwupdmgr get-updates
Devices with no available firmware updates:
• FORESEE P709F128G
• System Firmware
• UEFI Device Firmware
• USB2.0 HD UVC WebCam
ASUS BR1102FGA BR1102FGA_BR1102FGA
└─UEFI dbx:
│ Device ID: 362301da643102b9f38477387e2193e57abaa590
│ Summary: UEFI revocation database
│ Current version: 466
│ Minimum Version: 466
│ Vendor: UEFI:Linux Foundation
│ Install Duration: 1 second
│ GUIDs: 6c9777b8-19f2-5e2c-9210-66ef3691a9f3 ← UEFI\CRT_C3E5C7D58D7EE6C6844FEF2F6ECAA3F5F8B5BAFD800BC6F0275D140CB0688967
│ c8749f7f-439b-5c3c-a2ea-3baacf663a5a ← UEFI\CRT_C3E5C7D58D7EE6C6844FEF2F6ECAA3F5F8B5BAFD800BC6F0275D140CB0688967&ARCH_X64
│ c6682ade-b5ec-57c4-b687-676351208742 ← UEFI\CRT_A1117F516A32CEFCBA3F2D1ACE10A87972FD6BBE8FE0D0B996E09E65D802A503
│ f8ba2887-9411-5c36-9cee-88995bb39731 ← UEFI\CRT_A1117F516A32CEFCBA3F2D1ACE10A87972FD6BBE8FE0D0B996E09E65D802A503&ARCH_X64
│ 7d5759e5-9aa0-5f0c-abd6-7439bb11b9f6 ← UEFI\CRT_ED1FE72CB9CA31C9AF5B757AFCD733323D675825032E6CED7FE1AE9EB767998C
│ 0c7691e1-b6f2-5d71-bc9c-aabee364c916 ← UEFI\CRT_ED1FE72CB9CA31C9AF5B757AFCD733323D675825032E6CED7FE1AE9EB767998C&ARCH_X64
│ Device Flags: • Internal device
│ • Updatable
│ • Supported on remote server
│ • Needs a reboot after installation
│ • Only version upgrades are allowed
│ • Signed Payload
└─Secure Boot dbx:
New version: 20241101
Remote ID: lvfs
Release ID: 108324
Summary: UEFI Secure Boot Forbidden Signature Database
Variant: x64-compat
License: Proprietary
Created: 2023-05-09
Urgency: High
Vendor: Linux Foundation
Duration: 1 second
Release Flags: • Is upgrade
Description:
This updates the list of forbidden signatures (the "dbx") to the latest release from Microsoft.
    An insecure version of Howyar's SysReturn software was added, due to a security vulnerability that allowed an attacker to bypass UEFI Secure Boot.
rainbow@rainbow-ASUS-BR1102FGA-BR1102FGA-BR1102FGA:~$ sudo fwupdmgr update
• FORESEE P709F128G
• System Firmware
║ Upgrade UEFI dbx from 466 to 20241101? ║
║ This updates the list of forbidden signatures (the "dbx") to the latest ║
║ release from Microsoft. ║
║ An insecure version of Howyar's SysReturn software was added, due to a ║
║ security vulnerability that allowed an attacker to bypass UEFI Secure Boot. ║
║ UEFI dbx and all connected devices may not be usable while updating. ║
Perform operation? [Y|n]:
Downloading… []
Decompressing… [
Decompressing… []
Authenticating… [
Authenticating… []
Restarting device… [
Writing… []
Decompressing… [
Writing… []
Waiting… [***************************************]
Successfully installed firmware
An update requires a reboot to complete. Restart now? [y|N]:
rainbow@rainbow-ASUS-BR1102FGA-BR1102FGA-BR1102FGA:~$ sudo rm /var/lib/fwupd/pending.db
@AZorin @Aravisian
So i dunno if it's directly related but I ran the following in terminal and rebooted and now the dbx update is finally gone from software update.
sudo apt purge fwupd
sudo apt autoremove
The package fwupd is the Firmware Updater.
The firmware update daemon checks for updates, including the dbx package you have been having trouble with... thereby putting an end to the attempt to try to install it.
Ah ok is it a bad thing I did or?
I would call it a workaround not a solution.
In your case, it applies. You have consistently kept Secure Boot disabled in BIOS and therefor, have no need of the dbx package; no need to be nagged about it.
For a person that is dual booting Windows and is using Secure Boot; they may need a solution.
Ok thank you for always being helpful for us who aren’t so well versed. I appreciate ya. :smiling_face_with_three_hearts:
