I am encountering a problem for few days. I just have started playing "Counter Strike Global Offensive" from Steam. But strange this game crashes my computer, sometimes it getting freezes. This issue occurs only playing this game. I am telling this because I have tried playing other games on Steam, at that time Steam performs fine.
I cant understand why the problem is starting when I play Counter strike. Can someone help here? Thank you in advance
If it's only Counter Strike that crashes, you better take it to their support forum, as it seems to be a problem with their game and not your computer.
You tag this thread as a Windows problem. You know this is a Linux forum for the Zorin OS?
Hello :))
Could you please tell us your GPU manufacturer and model?
Also have you had trouble running other source engine games(Half-life/Portal/Team Fortress/...) ?
I assume you are running Zorin 15.3 core. Any additional details that you may provide will help us help you more.
Nvidia GeForce RTX 3070 - DDR6- 8GB and Zorin 15.3 lite has installed. I hope the problem is not arising for Zorin and also my PC configuration is fine. Hope the main culprit is present on the game.
I'm not sure if Z15 support such new cards? Is nvidia driver 465 available on Z15? If not you might try Z16 beta. I uses myself Z16 so I can't check it.
Yes, I did not mention here this issue that except Steam, my computer is crashing and sometimes it freezes while playing other games. I checked out the device driver that was updated. I cant understand what should do.
Oh okay. Earlier you mentioned that only csgo crashes so I was thinking of other solutions. It seems that the issue is with the Graphics Card driver. Try following the steps found at the Top Solution here and try to install the driver for your GPU. Let us know if it helps you.
Actually, the device driver was not updated. After checking properly and updating the problem got solved. I played almost 1-2 hours continuously, there was no crashing.
I also cleaned up the all temp file. Sometimes it may cause for crashing computer. Now I enjoy playing games. Thank you so much everyone.
PROTON is like the API that gives you all the power of the compatibility universe at your finger tips, to make the games work, and stop being annoying. I like PROTON. And for the record, so does the Ghost Busters, just gotta make sure you don't cross the streams, or you will cause a parabolic destabilization of the quantum universe, you don't want that. Cause it will send all the games code to Microsoft, then you will have been owned, rather then you doing the owning.
Because it is dependent on your computer's configuration, there is no suggested setting to follow. You'll have to go through them all until you locate one that doesn't break your machine. I had the same problem when I played csgo, also while accessing csgo gambling sites [/url] that happened because of some scripts, but now it works well. By the way are here people who are interested in gambling? I want to start a community where will be a lot of stuff about how to start to trade and gamble, strategies about this…
While the forum does aspire to be a bit more interesting than just a HelpDesk, I think gambling still falls outside of scope.
Nothing is stopping users from sending you messages privately on the topic, but gambling itself cannot be a supported activity Of this forum or on the Forum.
As such, the forum is not responsible for debtors, lost class rings or loan sharks.
I agree, there is gonna be no gambling on this forum, please go to actual websites dedicated to gambling, or, start your own gambling/trading site. Because it won't happen here.
