hey i am using anbox emulator for running android apps my apks are working properly but when i install play store apk it does'nt works properly so anyone can help me how to easily set playstore in anbox
PlayStore is Proprietary for Google. It will not work in Anbox.
Hi @zsarthak99!
Maybe you could try using aurora store, from the f-droid repository. Just so you know, I never used anbox or aurora store, so I have no pratical knowledge in this. But it seems a way you could try using "play store" on anbox.
See if waydroid is any better:
That is untrue.
GeeksR'Us has made scripts and guides on re-imaging anbox with the Google Play Store.
Ah, thanks for clarifying that. I did not know that anything has been done about that sdk.
I had checked this out sometime back trying to get Boom Beach on an Android emulator... But it required Google Play.
