Hi, recently when windows were my main os I've been enjoying the new free Fxsound(old dfx audio enhancer) a lot. I do encourage you if have any access to windows via dual-boot or emulator test it and see how it's so great.
btw in Linux, the only new options I discovered were PulseEffects or easyeffect which are actually great but they lack good quality presets and effects.
I mean if you see in Fxsounds there is a whole bunch of presets for every type of audio and they are actually pretty well doing the exact job even in addition there are some more downloadable from their site or elsewhere.
so anyone knows any presets for them or is it possible to run fx sound via wine to control audio outputs?
FxSound is great for improving audio quality on Windows, especially with its presets and sound enhancement options. On Linux, PulseEffects (now commonly associated with EasyEffects) is also a useful option, offering features like equalization, bass enhancement, and other audio effects.
The best choice depends on your Linux distribution, audio setup, and the kind of sound you want. If you're looking for more information, you can also check out this guide: (ativadorcrackeado.com.br/sound-booster/ .Hopefully, it helps anyone looking to improve their audio experience on Linux!
