Anydesk connection denied
Using Anydesk, I am unable to establish a connection from my Windows 10 and 11 PCs to my Zorin 18 machine. Does anyone know why this is happening and how to fix it? Anydesk permissions on my Zorin machine are enabled.
Wayland is not supported need to login with x.org. Logout on the Zorin machine click your username and look for a gear icon at the bottom right of screen click and select Zorin on Xorg. Should work then.
The solution was so simple that I didn't even think of it. You have to click on “sign in” without filling in the “client ID” or “tenant ID,” then you will be redirected to log in to the browser, then accept permissions, and that's it. I've tried it out a bit, and I'm really liking this native integration that comes with Gnome :slightly_smiling_face: (Apparently Mint also has this same integration).
Did it work using Wayland?
