hi, im using Zorin OS 17 and installed Anydesk from 'Software' app. its all working fine, but, this Anydesk wont autostart when i restart computer.
how can i make it to autostart or run it as services ? thanks
I am just guessing but maybe try using the X11 display driver instead of Wayland? Upon login, the gear icon on the lower left side or lower right side of screen will allow you to pick the different options.
yes, ive disable the Wayland from Terminal by : sudo nano /etc/gdm3/custom.conf, but still cant.
so now, i uninstall Anydesk from Software, then install manually from Anydesk.com using Ubuntu version.
now it work properly and run automatically.
thanks!
Please remember to mark whichever solution helped you with your initial problem. Even if it was your last post and you described your workaround. Thanks! ![]()
This helps future readers understand easily how the problem was resolved, or if people just forgot about it.
