Hello, I have a Lenovo laptop, in windows there was a Lenovo app that was able to keep battery charging level not going above 80% to extend battery life.
Question; Is there something similar in Zorin OS 18.1?
Any help would be very much appreciated.
Thank you!
Hi, Take a look here:
You need to scroll down to the Gnome solution.
Hi! thank you so much. I just installed the Battery Health Charging extension.
Is it working?
Yes! Thank you!
I moved the Solution marker to the actual post #3 that described the solution used.
