Archer TX3000E WiFi adapter not found
Hello all,
I apologize as I imagine this is a common topic but after researching for a couple days, I'm not sure what else I can do. I am new to Linux and can't seem to get my WiFi adapter to work.
I have a TP-Link Archer TX3000E PCIe wireless adapter installed on my desktop. The WiFi settings page is showing "No WiFi adapter found".
I've provided some terminal responses which I assume might help?
uname -a response:
6.14.0-37-generic #37~24.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Nov 20 10:25:38 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
lspci -knn | grep Network -A3
01:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
	Subsystem: Intel Corporation Wi-Fi 6 AX200NGW [8086:0084]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
[sudo] password for system-admin:
  *-network
       description: Network controller
       product: Wi-Fi 6 AX200
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 1a
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list
       configuration: driver=iwlwifi latency=0
       resources: irq:16 memory:f7e00000-f7e03fff
  *-network
       product: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: enp3s0
       version: 06
       serial: fc:aa:14:25:74:9d
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.14.0-37-generic duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.1.154 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:18 ioport:e000(size=256) memory:f7d00000-f7d00fff memory:f0000000-f0003fff
I appreciate any assistance.
Are you dual-booting alongsided Windows?
If true, from Windows Power settings, disable Fast Start-Up.
then boot Zorin again.
See this: AX200 wifi adapter not found - #2 by Jeremy31 - Support and Help - Ubuntu Community Hub
ZorinOS is the only OS on the drive. I installed it over a windows installation, but wiped the drive while doing so.
Well I gave up trying to get this card to work. I ended up buying a BrosTrend AX900 USB wifi adapter, which claimed to be compatible with Linux. After installing their drivers, it works great.
Is it fair to mark your last post as :white_check_mark:Solution?
