Dont know if its the same guide anymore? There are alot of different versions and distros i guess. I dont know wich one to choose. I found the driver here but i have no idea how to install it. Lets say i unpacked it in downloads. What then?
It downloaded the driver to my downloads. When i paste bsdtar -xzf 20200909_LINUX_BT_DRIVER_KERNEL_5.7_COEX_v0202.zip i get
Command 'bsdtar' not found, but can be installed with:
Yes i have extracted all files in my download folder. How do i install it from that place? There isnt any installer in the folder there are just four folders and four files.
Hmm dont know if i m doing something wrong. Downloads is translated to "Hämtningar" in swedish. I clicked on the Z button and typed Terminal. I then typed cd /Hämtningar/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202 but i get "No such file or directory".
This is the path for me using Filemanager:
/home/joeled/Hämtningar/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/20200806_LINUX_BT_DRIVER_RTL8761B_COEX_v0202/
Yes i managed to install it but now bluetooth is disconnected. I tried to start it again but no devices are visible. It doesnt want to start bluetooth at all.
Ok so bluetooth was working, but now is not after installing the driver. Did you reboot?
If bluetooth was working before, what were you trying to correct by applying the new driver?
