This is the proper command to use at this time for the TuxInvader kernel.
Once done, please reboot (Should automatically boot into the higher kernel)
and check
uname -r
Ensure you are using the 5.19 kernel - and test your system...
If this fails
You may need to tap the esc key or the tab key beginning at the Mother board splash screen to pull up the Grub Menu.
Move to Advanced Options for Zorin and select the previous working kernel to boot into.
I do not have any reason to believe you will get different results trying that again.
That issue relates to using the DisplayLink driver for Asus machines, not Lenovo.
I could be wrong, of course.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 06cb:00bd Synaptics, Inc.
Bus 001 Device 002: ID 13d3:56bb IMC Networks Integrated Camera
That is interesting, the usb monitor is not even listed in lsusb. All it returned were the USB hubs, USB 2 and 3 ports and your notebook's touchpad and camera. This suggests it is not recognised by the system at all. I asked for the output as normally the xxxx:xxxx hexadecimal device code can be checked against a kernel website so it looks like the monitor may never be recognised by GNU/Linux due to Asus inability to make it compatible.
Don't know if anything useful here on an old askubuntu thread.
Oh, I'm sorry about that @swarfendor437 — I didn't have the USB monitor plugged in at the time I ran that Terminal command. Here is the output after plugging it in:
Bus 002 Device 003: ID 17e9:ff0b DisplayLink ASUSTEK MB169B+
