steelx
January 9, 2021, 4:05pm
1
Im using Asus Zenbook Pro Duo laptop.
It has Intel i7 and Intel+ Nvidia (RTX 2060) gfx. 32GB RAM
When I change the brightness, the UI shows up on screen but doesnt change anything in screen brightness.
╭─ /usr/share/X11/xorg.conf.d ····· ✔ at 09:34:59 PM ─╮
╰─ ls ─╯
10-amdgpu.conf 10-radeon.conf 70-wacom.conf
10-nvidia.conf 11-nvidia-prime.conf
10-quirks.conf 40-libinput.conf
╰─ cat 11-nvidia-prime.conf ─╯
# DO NOT EDIT. AUTOMATICALLY GENERATED BY gpu-manager
Section "OutputClass"
Identifier "Nvidia Prime"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
Option "IgnoreDisplayDevices" "CRT"
Option "PrimaryGPU" "Yes"
ModulePath "/x86_64-linux-gnu/nvidia/xorg"
EndSection
╰─ cat /sys/class/backlight/intel_backlight/brightness ─╯
6960
Similar problem with Sound keys, sound always stays at 100% even I reduce it all the way to zero.
carmar
January 9, 2021, 6:21pm
2
Hi, steelx.
Please provide the output of lspci.
I’ve experienced problems like you. The screen brightness can’t be adjusted when I haven’t upgraded the RAM to be bigger. however since I have upgraded the RAM (From 2GB to 8GB), I never had that problem.
i am using ASUS a45a.
Try to check the free capacity of RAM.
I don’t know whether this is related or not. I just share my experience.
steelx
January 10, 2021, 12:24pm
4
╭─ ~ ······························ ✔ at 05:53:58 PM ─╮
╰─ lspci ─╯
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation Device 3e9b
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 07)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:15.0 Serial bus controller [0c80]: Intel Corporation Device a368 (rev 10)
00:15.1 Serial bus controller [0c80]: Intel Corporation Device a369 (rev 10)
00:15.2 Serial bus controller [0c80]: Intel Corporation Device a36a (rev 10)
00:15.3 Serial bus controller [0c80]: Intel Corporation Device a36b (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:1b.0 PCI bridge: Intel Corporation Device a340 (rev f0)
00:1b.4 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port 21 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port 9 (rev f0)
00:1d.7 PCI bridge: Intel Corporation Device a337 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Device a30d (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f11 (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10f9 (rev a1)
01:00.2 USB controller: NVIDIA Corporation Device 1ada (rev a1)
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation Device 1adb (rev a1)
03:00.0 PCI bridge: Intel Corporation JHL6340 Thunderbolt 3 Bridge (C step) [Alpine Ridge 2C 2016] (rev 02)
04:00.0 PCI bridge: Intel Corporation JHL6340 Thunderbolt 3 Bridge (C step) [Alpine Ridge 2C 2016] (rev 02)
04:01.0 PCI bridge: Intel Corporation JHL6340 Thunderbolt 3 Bridge (C step) [Alpine Ridge 2C 2016] (rev 02)
04:02.0 PCI bridge: Intel Corporation JHL6340 Thunderbolt 3 Bridge (C step) [Alpine Ridge 2C 2016] (rev 02)
05:00.0 System peripheral: Intel Corporation JHL6340 Thunderbolt 3 NHI (C step) [Alpine Ridge 2C 2016] (rev 02)
3b:00.0 USB controller: Intel Corporation Device 15db (rev 02)
3c:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981
3d:00.0 Network controller: Intel Corporation Device 2723 (rev 1a)
steelx
January 10, 2021, 1:40pm
5
thanks for stopping by. but its not RAM issue.
steelx
January 10, 2021, 5:22pm
7
zorin latest. 15.3 Core.
Also I tried what you mentioned. still no effect.
got the latest drivers which came with Zorin os, which I installed yesterday.
carmar
January 10, 2021, 5:33pm
8
You have 2 gpus:
Check your BIOS for anything termed similar to “discrete graphics” (or anything where the system is allowed to switch between cards at will) and toggle the settings to turn it on/off. That is the cause of the problem.
You also have 2 sound cards:
This is also the cause. Again, check BIOS.
steelx
January 11, 2021, 3:56am
9
Solution here (added by moderator): Asus Zenbook Pro Duo 2nd screen display issue - #18 by steelx
steelx original post follows:
Thanks for getting back.
I have Windows 10 + Zorin OS 15.3 installed on 1 SSD.
Attaching screenshot of BIOS, I could not find anything related to term discrete graphics
The one option which I found under Advanced -> Graphics Configuration -> "64M" just a input field (but did not had any toggles or term "discrete graphics")
carmar
January 11, 2021, 4:44am
10
While you’re there, you may want to look for an option to go with one sound card. If there is no option then try this: https://askubuntu.com/questions/110835/how-to-disable-the-internal-sound-card
There is a way to turn off hybrid graphics: http://www.toontricks.com/2018/03/ubuntu-how-do-i-disable-intel-graphics.html
If the methods in this above link don’t work, you can try the method here: https://help.ubuntu.com/community/HybridGraphics (its solution #2 from the prior link but expanded out a bit more sensibly) - for this one, jump to “These settings are stored in grub’s (the bootloader) own setting files in /etc/default/grub” and start from there.
I'm a bit confused by the solution in this discussion. Maybe my knowledge with regard to computer terminology isn't sufficient for this forum but I'm desperate for a solution to my screen brightness not working on my ASUS UX535LI (Zenbook pro duo).
That being said, mine is stuck in the full bright position. Hard keys don't work, disabling and reenabling, uninstalling and reinstalling drivers didn't work. I tried updating the firmware in my NVIDIA graphics card. Part of that solution was to disable the SLI configuration. However, mine doesn't have an option to do so. So, I'm stuck and out of options to this point. Can anyone help?
Have you tried installing Brightness Controller? It works well on my machine.
sudo add-apt-repository ppa:apandada1/brightness-controller
sudo apt update && sudo apt install brightness-controller
