Audio got bricked
the whole thing to reproduce is like listened there
but long story, short meaning i tried installing easy effect it couldnt use my mic then i got told pipewire is installed wrong i installed an packet now my sound thing is bricked i cant hear and my mic is like not showin (my zorin is in german, just so you know)
i reinstalled pipewire now its that
(still mic and headset is gone)
Are you on Zorin 17 or 18? Do you use the default audio server (in Zorin 17 pulseaudio, in Zorin 18 pipewire)?
Im on zorin os 17.3 education and what audio server i use idk
Open terminal typing Ctrl+Alt+T
type:
alsamixer
Hit F6 to show soundcards.
Do you have more than one soundcard?
Hit F5 to show all sound channels, both inputs and outputs.
Post a screenshot.
Try unmuting any mic and headphone channels marked "MM" by using arrow keys to the channel and type "M" to unmute. Increase volume using up-arrow.
Also play with Auto-Mute and Loopback-mode channel settings and see if any effect.
and it seems like idk that theyre werent muted but ima see if they show up now
but this automute mod irritates me i just turned it off
From F6 select HD-Audio Generic
oh wait yeah i restarted its back now bro tysm
Hit F5 to show all channels. Note there are channels on right and left of screenshot shown by columns of arrows.
Have a play around with alsamixer unmuting channels marked [MM] and see if any effect.
like it works now and if i press f5 it just shows that
i have my channels back now with headset n stuff tysm
