Audio Issue after power on from hiberneation or close display
Technical infos
uname -a
6.17.0-23-generic #23~24.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue Apr 14 16:11:48 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
inxi -A
Audio:
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel
API: ALSA v: k6.17.0-23-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
play -l
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: PCH [HDA Intel PCH], Gerät 0: ALC269VB Analog [ALC269VB Analog]
Sub-Geräte: 1/1
Sub-Gerät #0: subdevice #0
Karte 0: PCH [HDA Intel PCH], Gerät 3: HDMI 0 [HDMI 0]
Sub-Geräte: 1/1
pactl list sources
Quelle #51
Status: SUSPENDED
Beschreibung: Monitor of Built-in Audio Analoges Stereo
Treiber: PipeWire
Abtastwert-Angabe: s32le 2ch 48000Hz
Kanalzuordnung: front-left,front-right
Besitzer-Modul: 4294967295
Stumm: nein
Lautstärke: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
Verteilung 0,00
Basis-Lautstärke: 65536 / 100% / 0,00 dB
Ziel-Monitor: alsa_output.pci-0000_00_1b.0.analog-stereo
Latenz: 0 usec, eingestellt 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Eigenschaften:
alsa.card = "0"
alsa.card_name = "HDA Intel PCH"
alsa.class = "generic"
alsa.components = "HDA:10ec0269,10250686,00100100 HDA:80862806,80860101,00100000"
alsa.device = "0"
alsa.driver_name = "snd_hda_intel"
alsa.id = "PCH"
alsa.long_card_name = "HDA Intel PCH at 0xd3610000 irq 32"
alsa.mixer_name = "Realtek ALC269VB"
alsa.name = "ALC269VB Analog"
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
api.alsa.card.longname = "HDA Intel PCH at 0xd3610000 irq 32"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "front:0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
card.profile.device = "4"
device.api = "alsa"
device.class = "monitor"
device.id = "44"
device.profile.description = "Analoges Stereo"
device.profile.name = "analog-stereo"
device.routes = "2"
factory.name = "api.alsa.pcm.sink"
media.class = "Audio/Sink"
device.description = "Built-in Audio"
node.name = "alsa_output.pci-0000_00_1b.0.analog-stereo"
node.nick = "ALC269VB Analog"
node.pause-on-idle = "false"
object.path = "alsa:pcm:0:front:0:playback"
priority.driver = "1009"
priority.session = "1009"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "35"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "51"
object.serial = "51"
api.acp.auto-port = "false"
api.acp.auto-profile = "false"
api.alsa.card = "0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio0"
device.bus = "pci"
device.bus_path = "pci-0000:00:1b.0"
device.enum.api = "udev"
device.form_factor = "internal"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_00_1b.0"
device.nick = "HDA Intel PCH"
device.plugged.usec = "12893455"
device.product.id = "0x1e20"
device.product.name = "7 Series/C216 Chipset Family High Definition Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.vendor.id = "0x8086"
device.vendor.name = "Intel Corporation"
device.string = "0"
Ports:
analog-output-speaker: Lautsprecher (Typ: Lautsprecher, Priorität: 10000, Verfügbarkeitsgruppe: Legacy 3, Verfügbarkeit unbekannt)
analog-output-headphones: Kopfhörer (Typ: Kopfhörer, Priorität: 9900, Verfügbarkeitsgruppe: Legacy 4, nicht verfügbar)
Aktiver Port: analog-output-speaker
Formate:
pcm
dmesg | grep alc269
[ 12.866723] snd_hda_codec_alc269 hdaudioC0D0: ALC269VB: picked fixup for PCI SSID 1025:0000
[ 12.868010] snd_hda_codec_alc269 hdaudioC0D0: autoconfig for ALC269VB: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 12.868016] snd_hda_codec_alc269 hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 12.868020] snd_hda_codec_alc269 hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 12.868023] snd_hda_codec_alc269 hdaudioC0D0: mono: mono_out=0x0
[ 12.868025] snd_hda_codec_alc269 hdaudioC0D0: inputs:
[ 12.868028] snd_hda_codec_alc269 hdaudioC0D0: Mic=0x18
[ 12.868031] snd_hda_codec_alc269 hdaudioC0D0: Internal Mic=0x1b
play -l
Sub-Geräte: 1/1
Sub-Geräte: 1/1
No audio output after reactivate
Test in VLC / Audacity and other - playing without sound
pactl list short sinks | grep SUSPENDED | awk '{print $1}' | xargs -I {} pactl suspend-sink {} false
  • no change
Are Secure Boot and Fast Boot in BIOS disabled? Does this only happen when it goes automatically in Hibernation or manually or both? Does it affect only built-in Speakers or external (wired and wireless), too? Did You tried Pulse Audio Volume Control? It is a Program for set up Audio Output and Input. You can install it with the Command sudo apt install pavucontrol and when installed, check the Configuartion and Output Tab's for Audio Profiles and Options.
pulse audio cant handle this issue
  • solved by by install hdajackretask and assign parameter
