Audio not coming
only this happen during google meet on another platform I didnot check like zoom or teams.
How is google meet installed? If snap or flatpak, those packages run self-contained and can give system integration issues.
Edit: Im also wondering about your soundcard.
Have you looked at Software & Updates>Additional Drivers?
Is your HP Victus very new. That may play a part.
using web browser google chrome
google chrome, so I assume that is snap or flatpak,
So my comment: "those packages run self-contained and can give system integration issues." could apply.
Any difference if you use the browser that comes with ZorinOS i.e. Brave ?
I assume you have played with headphone mic settings in google meet itself, before asking here.
EDIT: are you dual-booting alongside Windows? If true, is Windows>Settings>Power Fast Start-up disabled?
I am using zorin only but in brave it is working fine but in chrome it is not working properly
How did you install chrome?
from software center
What source e.g. Zorin, Flatpak, Snap ....
flathub
Noted. You may want to read this regarding chrome flatpak potential limitations: Clean reinstall of Chrome - #5 by Aravisian
If google meet headphone and mic are good on Brave browser, also headphone and mic are good on other apps except Chrome (flatpak) then that dispels a hardware/driver failing.
If you must have Chrome browser and want to use google meet using it, then you would be better to install as a .deb
