Audio not working for HP Envy 17.3"
You are not alone in this:
I wonder if the suggested patch would work on your HP Envy...
This all looks like greek to me! Any way you can help me break it down so I can try it? Or maybe there's an easier solution?
Sorry, it was late and I was not clear.
What I had meant was that I may be completely wrong and installing the latest kernel may help.
You can try it with Secure Boot disabled in BIOS Settings:
sudo add-apt-repository ppa:tuxinvader/jammy-mainline
sudo apt update && sudo apt install linux-generic-6.06
Or
sudo apt update && sudo apt install linux-generic-6.07
Reboot to boot into the later kernel to test.
not working still... any new ideas?
Looking back at this earlier post #17.
What happens if you select "Analogue Stereo Output" option from that list.
nope. it still doesn't work... any more ideas? it is a shame because this computer has a BANG&OLUFSEN audio system I really want to use!
