It is after something I did yesterday, my laptop is not giving any sound. Can anyone review and help me with my issue?
Try, Installing Volume Control for PulseAudio.
pulseaudio --start
sudo apt install pavucontrol
Also, Try checking alsamixer configuration in the terminal.
If not working reload alsamixier.
sudo alsa force-reload
Also, can you please give an overview on what you did?
I did a lot, installed proton, dolby audio plugin and updated my system, installed new drivers.
This made the Sound Work
Thanks Man🤝
