hi, i've installed zorin 16pro on chuwi herobox pro, a celeron n4500 .
here the result of lspci
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Device [8086:4dc8] (rev 01)
DeviceName: Onboard - Sound
Kernel: 5.11.0-46-generic
someone can help me?
Good day. You can try this link https://www.linuxuprising.com/2018/06/fix-no-sound-dummy-output-issue-in.html?m=1
I had problem with another os and it worked for me.
westdam
February 5, 2022, 11:10pm
4
Nope doesn't work . Any other ideas?
carmar:
Marked solution. 211
I don't understand this one @carmar . Was it marked then unmarked? I see no marked solution or unmarked solution for that matter here.
In terminal (ctrl+alt+T) type alsamixer
Hit F6 and see what sound card options you have.
Hit F5 to display all sound channels. Post a screenshot.
Scroll across each channel and unmute each using "M" key and increase the level using "up arrow" key.
Check that "Auto-Mute" is disabled.
It was unmarked after the O.P. returned and said that the solution did not work.
westdam
February 17, 2022, 10:43pm
8
i'll post a screenshot asap , it's on my parent's house.
system
Closed
May 18, 2022, 10:43pm
9
