How Autoconnect ProtonVPN?
command line.
r00p, maybe this full length guide can help you get all set up:
Please ask if any details need clarification or if it does not work.
found easy way
download .ovpn file and add VPN > import from file>select ovpn.
Enter username and password if asked in "identity"
sudo apt install network-manager-openvpn network-manager-openvpn-gnome openvpn openvpn-systemd-resolved -y
nm-connection-editor
Select WIFI or ethernet >
,General > Automatically connect to VPN.
check with off and ON WIFI.
