Hi pheph9 and other Zorin OS users,
I saw your post in the Zorin forum about an automated install tool, and I am actually using one to do some stuff for my job. It is called Cubic, and it stands for Custom Ubuntu ISO Creator. It allows you to do application installs, partition setups, user setups, anything that you need to make a custom ISO. The author has a forum and even responded to me directly when I had some questions.
You should definitely check this out.
Please understand that I have no connection or benefit from recommending Cubic other than being a very satisfied user.
Good luck.
Regards,
mikejp56
I use cubic as well, (recently found it) combined with a pxe server for my vm lab. But the setup would work great for larger scale deployment
