Hi,
I am running Zorin 17 core, my Q is can I get the wallpaper/ background to change automatically daily if so how?
many thanks
Brian
Try "Variety". It's in the software Store.
You can use Gnome extensions too for changing wallpapers automatically.
https://extensions.gnome.org/extension/543/backslide/
Also, there are more extensions and app to connect to online providers
I've got Variety installed but the privacy page overfills the screen and I cannot scroll to the bottom of the page to select any OK or agree button which seems to stop it loading or working.
If you hold the alt
key down, you can then click and hold on any area of a window to move it, then you have access to buttons or to the window borders to resize it.
