I have setup a Zorin OS 16 and everything works so far pretty neat.
My only problem is that I have difficulties in connecting to a hidden WiFi (5GHz only) that is meshed using four devolo Magic 2 devices.
Manually it is no problem to connect and using a 2.4 GHz network from a mobile router is working, as well as connecting with the same MacBook running MacOS.
"lspci" output looks good to me:
lspci -knn | grep Net -A3; rfkill list
03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter [14e4:43a0] (rev 03)
- Subsystem: Apple Inc. BCM4360 802.11ac Wireless Network Adapter [106b:0117]*
- Kernel driver in use: wl*
- Kernel modules: bcma, wl*
so does "lshw -class network":
**-network *
description: Wireless interface*
product: BCM4360 802.11ac Wireless Network Adapter*
vendor: Broadcom Inc. and subsidiaries*
physical id: 0*
bus info: pci@0000:03:00.0*
logical name: wlp3s0*
version: 03*
serial: 9c:f3:87:bd:a7:00*
width: 64 bits*
clock: 33MHz*
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless*
configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=192.168.2.196 latency=0 multicast=yes wireless=IEEE 802.11*
resources: irq:18 memory:b0600000-b0607fff memory:b0400000-b05fffff*
I did fire out the reinstall of the kernel drivers that seem to get lost from time to time, but that didnt do the trick either:
apt-get install --reinstall bcmwl-kernel-source
And I turned of the power management, just to prevent anything going south through that using iwconfig:
*wlp3s0 IEEE 802.11 ESSID:"XXYYZZXXYYZZ" *
Mode:Managed Frequency:5.18 GHz Access Point: XX:XX:XX:XX:XX *
Retry short limit:7 RTS thr:off Fragment thr:off*
Power Management:off*
Any ideas on how to look at this further?
