Hi, I have a computer (Zorin 15 Lite) with autologin in use. Now it changes to be my kids Computers and they got a new user.
How can I switch the autologin off? Can't find it in the settings
Auto login is located at users in settings. Type in you'r password to unlock and then turn auto login off
no, it's not in Zorin Lite.
There is just the question for the type and the passwort but not for the autologin (as it is in Ubuntu Gnome).
That's where I searched first...
Oh your are on lite, I did not notice that part😅
yeah, can't find a way to change autologin there
Are you on lightdm or gdm?
no idea... it shows "Zorin Desktop"
Try cat /etc/X11/default-display-manager in terminal. Post the output here.
lightdm
Okay, I'll be out for 20 minutes, so will have to give you a link. Try what is being said in there. If it doesn't work we will try a different way.(It is a really old question asked on askubuntu. So may not work.)
I suggest trying the second solution first!
Thanks, that worked. Actually I hoped it would work in the settings, but changing lightconfig made it work, too
Good to hear that news.
I am really impressed with you today, you did a great job in providing support. ![]()
