Kernel Panic = Not Good
I see relation to timer doesn't work. Is it possible that your CMOS battery needs replacing?
StarTreker
Community Tech Support
Boot into Recovery Mode
Drop To Prompt
sudo nano /etc/default/grub
Change GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash noapic"
Exit and save, then attempt a normal boot.
Ah, right.
I just noticed this acpi related error message!
Marked Solution. 340
