i have installed zorin os twice, and both the times the dislpay quality in any browser was really bad, it was not crisp and all the text is blurry, the last i had run a script as a startup application which forces gpu acceleration but that was a bad idea since but drained my laptops hell fast! so i needed help to improve my brave's and chrome's display quality (since i for 99% of the time am on the browser)
- Are Brave and Chrome Flatpaks or APT/.deb's?
- How are Resolution and Refresh Rate set up?
- Is Fractional Scaling active?
- Does Your System run in Wayland or X11/Xorg? You can check that in Settings>About
- What are Your Hardware Specs?
