How I install this USB 3G BAM in this distribution thanks to your support
I have no idea what this is, perhaps if you provide a link I can understand.
This is all I can find: https://www.mobifreedom.net/unlocking-instructions-for-huawei-e188 - so it must be one of those devices
Try connecting it and then going to Zorin menu -> Settings -> Network and then probably a selection under the Wired category.
Thanks for your reply sorry to dont explain about my problem. Listen
I have this USB 3G Mobile Broadband Modem and I try to install in Zorin but the systems only reconize this to a pendrive. I need install this to use wireless connectivity. Thanks
Can you confirm that the Settings -> Network suggestion, earlier, doesn’t work for you?
If so, try the steps here: https://aaronlelevier.github.io/install-usb-wifi-dongle-on-ubuntu-18.04/
I resolve the problem in this form.
1.- Put the USB 3G BAM in the slot the system detect this later copy the folder Linux to the home directory name the directory temp.
2.- change to this directory in the terminal chmod + x to the script install.
3.- Execute the script some errors found but wait the driver copy to the system.
4.- Restart the system and detect the BAM 3G enter in configure and finish them.
