I have two Zorin 16.2 Pro installations. A NUC & Surface Pro 4. When I set the NUC as Server & SP4 as client, they both stick in "Barrier is starting". If I reverse them, they work fine. If SSL is ENABLED, it sticks as well. They are both fresh installs of Z.
Gday @charlieuk ,
Welcome to our community!
Being Fresh install's, may i suggest running updates, have you pc's setup to how & what you want on them, Then run some updates.
reboot & you may need to run updates again.
Try here may give you an idea,
Thank you
You Welcome.
Please mark the post " solution" , This lets others know this Topic has been "Solved"
Regards Ocka
