Since my upgrade to ZorinOS 17 Pro, I have not been able to use Barrier.
I have turned off firewalls on both PC's, and eventually got both installs of Barrier to be in a "Running" state.
However, moving my mouse across the screen, it does NOT move to the next PC.
I am thinking this is something to do with Wayland?
Any suggestions would be appreciated.
It does appear that the devs of barrier did not have plans for Wayland support back in 2021:
You can change to Zorin on X at login. When you select your user name a cog appears bottom right of login screen, click on that to change to Zorin on X.
Wow! Thank you for your quick and detailed feedback.
I had "googled" for solutions but obviously did not use the right search terms, as your research has been far more effective!
I'm using de-Googled Chrome on Fairphone 3+ from /e/ foundation set to mojeek.com which doesn't always bring right answer but offers Brave search engine as first alternative.
