I have an Aorus Elite B550M motherboard and the sound is working normally. But I miss being able to control the bass and treble. Is there anything I can do?
Hm, you could take a look at the app easyeffects, it can improve the sound.
sudo apt install easyeffects
If you are on Zorin 17 or use pulseaudio instead of pipewire in Zorin 18 you could also test pulseeffects. But it doesn't work with pipewire (I tried to install it on Zorin 18 and got an error message that it depends on pulseaudio).
sudo apt install pulseeffects
I wonder if you would have a better chance with ALSA. qasMixer is good for multichannel controls (separate bass and treble, surround sound etc.).
Audacious is much better than Rhythm Box.
Take a look at my tutorial thread I created for SoundBlaster Audigy Rx - be sure to read the entire thread:
