Hello
First of all: I love Zorin OS Pro but
I have the problem that on my Surface that i dont have any Battery Indicator and i dont find any settings from the battery either.
Has someone an idea how to activate it or install it
Hello
Can you give me more system information?
Type the following into your terminal and give us the output:
sudo lshw
The command will show what devices you have connected to your computer.
You can also take a look Ubuntu – Battery indicator has disappeared from Gnome panel – iTecTec
