Battery info in one icon
I have a Panasonic cf 33 with 2 battery's and i can see the battery's just fine. But i would like to see both battery's on the task bar. And the quick pull up bar.
You can try it with that gnome extension:
Install the extension manager
sudo apt install gnome-shell-extension-manager
then open the extension manager at tab browse to search for the extension and install it.
