I recently discovered the bc terminal calculator, and I love it, especially how you can use variables!
But is there a way to have some sort of syntax colors to make everything more readable?
Hello, i don't have much knowledge about terminal but i don't think this is possible. If you want a colourful interface then why don't you use the calculator application.
But if you like this terminal interface and colours in calculator then you can install a calculator named SpeedCrunch
You can download that from here
Thanks! I'll try it out!
