I'd like to practice terminal commands and learning the syntax involved with the Linux command line. I will not be doing this on my actual install of Zorin OS 17 Pro, but rather in a VirtualBox environment using another OS. That is what I need help with here. What lightweight OS would you recommend to use in VirtualBox on Zorin OS? I understand that all distros are (at the heart of it) the same underneath, so the terminal would remain the same. But I'd also be interested in practicing on a Linux OS that would stay responsive in a virtualized environment. I have an i5-9400 CPU, 32 GB of RAM, and a 8 GB Radeon 580 RX video card. Do I go with XFCE?
Actually, I thought of Zorin OS Lite after my initial post above. Thanks for the other suggestions. Never heard of Asmi or Antix. I'll have to look into them both. Thanks!
The great thing about virtual machines is that you can create and throw them away at anytime, so pick and choose whichever distribution you like and play with it as much as you want.
The main differences you'll find between distributions is the default selection of software installed, the package manager and from time to time some minor differences as to where some configuration files are placed.
Installing Zorin OS 17 Core on VirtualBox. Zorin 16.3 Lite was interesting to try out and play around with. I can safely say that the Zorin Group made many correct choices in going from 16 to 17 in terms of UI design and functionality. I like 17 Pro very much, and I hope the Zorin Group stays on the same track going forward.
