How do folks prepare to upgrade to new versions of the same Linux distro? How do you keep track of installed apps and their settings?
I realize that old versions of apps may not successfully carry forward compatibly. We all hope that newer versions of those apps will be available and will work well.
Is there an inventory checker to report on apps which aren't in the official Zorin distro? Is a text file where we have to remember to note our actions the 'best practice' ?
Where would apps on Linux commonly store their settings? (I'm used to on Windows some old apps using .cfg or .ini files. Some use the Registry, and that's tougher to migrate to another machine, too.) In work environments some apps settings get stuffed into local/roaming profiles. Is the Linux equivalent of that the folder /home? Can that be successfully preserved and restored?
Do most folks create separate partitions on disk which don't get touched by the upgrade process? How would you tell your apps to look over there?
Sorry if this is all commonly well known stuff. If you know of other write ups about this please point me to them.
You are completely right. However, there are commands that will show all apps installed through APT, which would be the vast majority.
apt-cache pkgnames gnome | less
apt list --installed
This will list packages including those installed from a .deb:
Search a specific package:
apt -qq list program_name --installed
General search:
apt -qq list --installed
For snap packages, you can check with
snap list
Flatpack:
flatpack list
The Software channel App has a button on the toolbar for "Installed". While this is not much help for making a list easily, like the terminal commands above which can easily be copied to a .txt file, it does help sometimes for fast GUI daily checking things.
In your home folder, settings are stored in ~/.config. 337harvey's post about Partitioning to install while keeping your home partition will also keep all configuration and settings stored in ~/.config as well as ~/.local/share.
Shorthand - ~/ means your Home Folder.
After installing the new OS, open terminal and run:
sudo apt full-upgrade
to upgrade installed packages if upgrades are available. You *may need to install the appropriate repositories for some packages that you initially installed from a repo.
You can get your repo list easily with sudo apt update and copy the results to a .txt file, save in your ~/Documents.
No, but Linux is Open Source and it is not necessary to stick with only the Zorin Repository. In fact, Zorin OS also uses the Ubuntu Repository Main Server by default. If you want an app that is not available in the current repo list, just run a google or duckduckgo search for that app name repository. For example; if you want to install unetbootin, search unetbootin repository. It usually will point you to where to go.
