trying to install bibletime 3.0.3 ..
README says .. run build-release.sh. This will
also build in ./build/, but then install to /usr/local.
- Intel® Celeron(R) CPU N3060 @ 1.60GHz × 2
- Zorin OS 16.3
- 64-bit
- X11
error.. build-release.sh: 9: cmake: not found
i can navigate to parent folder /usr/local using Files App
or can navigate to same in terminal - i need to extract build-release.sh where prior to install?- because right now extracted to /home/pc/Documents/btime/bibletime-3.0.3
need to download cmake or no?
guide at GitHub - bibletime/bibletime: 📖 BibleTime is a powerful cross platform Bible study tool.
open to try alternatives listed at https://alternativeto.net/software/e-sword/?platform=linux if easier to install
